Activity Forums Panasonic Cameras Monitor Sync
  • Monitor Sync
    Posted by Chip Monk (hd tech) on April 27, 2006 at 1:48 am
    Hello,
    Trying to Sync to an NTSC Monitor for shooting. It looks pretty good at 24fps, 144 shutter, but there is a horizontal line in the image.
    Is there any way to “phase” that line to the bottom or top of the picture?
    Chip
    Bruce Greene replied 20 years, 5 months ago 2 Members · 1 Reply
  • Bruce Greene
    April 27, 2006 at 1:59 pm
    You could try using the syncro scan instead of the shutter speed presets to find a shutter speed longer than 1/48 sec that will sync.
    As for phase, all I can think of to try is A) turn off the camera and start it up again (probably remove battery) or B) try changing the fps to 23,22,21 or 25,26 etc and then back to 24 fps to see if the phase changes.
    Varicam/Steadicam Owner
    Los Angeles, CA
    http://www.brucealangreene.com
