Activity Forums Apple Final Cut Pro Monitor Situation driving me crazy…
  • Monitor Situation driving me crazy…
    Posted by Mark Smith on April 26, 2017 at 5:14 pm
    Editing on 5 K imac and have a secondary monitor set up which is for the browser. The monitoring set up has a workspace I’ve saved and named. When ever I open X the App in in single display mode with either the time line or browser displayed on the secondary monitor and a finder window on my primary which is the 5k imac. What gives here , I thought workspaces was there to define and save a monitor layout and it seems to do nothing at all?
    Duncan Craig replied 9 years, 4 months ago 3 Members · 5 Replies
  • Noah Kadner
    April 26, 2017 at 8:36 pm
    Also depends a bit on how you have the monitors arranged in systems preferences. ie physical layout and which is set as the menu for system.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Mark Smith
    April 26, 2017 at 9:47 pm
    The iMac is “arranged ” in system prefs as the monitor on the RH SIDE of the set up panel with the menu bar above . The secondary monitor appears on the LH side of the panel
    . Is this wrong somehow?
  • Duncan Craig
    April 26, 2017 at 10:10 pm
    It might also help to look at the ‘Displays have separate Spaces’ option in the OSX Mission Control preference pane… Perhaps change it and see if the problem persists.
    FS100, EX1, GoPro, 2x Hacks, FCPX etc
  • Mark Smith
    April 26, 2017 at 11:19 pm
    THanks- that OSX mission control setting for monitors have separate spaces had to be unchecked. Now FCPX displays come up the way I want them to when opening the program…
  • Duncan Craig
    April 27, 2017 at 8:55 am
    Ha! I really glad that sorted it.
