Activity Forums AJA Video Systems Monitor settings for PAL
  • Monitor settings for PAL
    Posted by Vince Sanchez on July 26, 2005 at 7:40 am
    I have an IO I have been using to do NTSC work, but now I’m starting a project that is in PAL and I’m confused as to how to set my monitor correctly. I have a Sony 14M4U connected to the IO via component out from the IO. In the menu there are 3 settings under component level.
    1. Smpte N10
    2. Beta 7.5
    3. Beta 0
    I am using an easy setup for PAL uncompressed 8 bit. The setting for output to the io is Component SMPTE N10 8bit. Should Iset the monitor to #1 or #3 or neither.
    Thanks for any help I can get
    Vince Sanchez
    G5 DP2.0ghz 2.5gig ram
    AJA IO
    OS10.3.9 QT7.01
    3X250gb SATA Hitachi HD 8meg cache stripped in array
    Sonnet 133mhz Sata card
    OWC firewire card
    Vince Sanchez replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
