Activity Forums Adobe After Effects monitor resolution. Higher always better?
  • monitor resolution. Higher always better?
    Posted by Brian Wells on May 29, 2012 at 2:28 am
    If I were to make a short video in AE and PP, 1920×1080, would it be better to get a 27 inch monitor that is 1920×1080? or one that has a higher resolution?
    Will the higher res somehow be a negative?
    Brian Wells replied 14 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 29, 2012 at 4:30 pm
    [Brian Wells] “If I were to make a short video in AE and PP, 1920×1080, would it be better to get a 27 inch monitor that is 1920×1080? or one that has a higher resolution?”
    I like hi-res monitors. A 2560×1600 (or 2560×1440) monitor has room for an entire 1920×1080 comp viewer plus other panels, like the timeline, effects controls, etc.
    [Brian Wells] “Will the higher res somehow be a negative?”
    If you increase resolution but leave the physical size the same, the pixels themselves become smaller. That means some of the UI elements can get pretty small on-screen.
    Walter Soyka
  • Brian Wells
    May 29, 2012 at 10:31 pm
    I sort of see your point. I was thinking though when I do a full screen preview in AE the with a 1920×1080, since output is 1920 by 1080,(I am planning to set the Res in AE to 1920×1080 output,renders whatever) each pixel will match nice and evenly, with a 1920 by 1080 monitor. Or doesn’t it work that way?? sell me your idea please Walter, or anyone else that want to chime in
