Activity Forums VEGAS Pro Monitor recommendation under $200
  • Monitor recommendation under $200
    Posted by Angelo Mike on September 10, 2014 at 1:02 pm
    My ~8 year old Envision G19LWk monitor is ok but horrible at displaying skin tones and blacks. Blacks look like some kind of photo negative. And it’s got a 1440×1080 resolution. It’s hard to believe I’ve been editing on this for the last five years.
    Is there a decent monitor under $200? Maybe I could push for $300 if it was recommended strongly and was something I could use for a long time. And I can’t think about getting a second monitor though I really want one.
    Angelo Mike replied 11 years, 11 months ago 3 Members · 4 Replies
  • Bob Peterson
    September 10, 2014 at 2:32 pm
    Are you using hardware like the Spyder Pro to calibrate your monitor? That will be needed for any monitor, and it may extend the life of your current one.
  • Angelo Mike
    September 10, 2014 at 6:47 pm
    No, but I wonder if there’s a way to do a trial run of that without actually buying it. I think my monitor may just be deficient in displaying blacks. How else do you explain blacks shining like they’re a photo negative, like an invert plugin has been used on them? I guess I’ll need it anyways and may as well try it out on this monitor.
  • John Rofrano
    September 12, 2014 at 11:13 am
    [Angelo Mike] “No, but I wonder if there’s a way to do a trial run of that without actually buying it.”
    It’s a piece of hardware so there is no trial.
    [Angelo Mike] “Is there a decent monitor under $200? Maybe I could push for $300 if it was recommended strongly and was something I could use for a long time.”
    My two ASUS ProArt PA246Q’s cost me $500 each at the time but they are accurate right from the factory. You can pick up an ASUS PA248Q 24″ LED Backlit IPS Widescreen Monitor for $291.23 USD at B&H Photo. That’s on the $300 side but worth every penny.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Angelo Mike
    September 12, 2014 at 1:16 pm
    Thanks, John. I’ll consider that strongly.
