Activity › Forums › Canon DSLR Cameras › Monitor Question
  • Monitor Question
    Posted by Patrick Morrow on August 14, 2014 at 4:45 am
    Looking for a large 20-30 inch monitor that works well with the Canon 70d. Also is there any that work with the T4i type cameras? Thanks!!!
    Patrick Morrow
    Warren Eig replied 12 years, 1 month ago 3 Members · 2 Replies
  • Ryan Holmes
    August 14, 2014 at 2:21 pm
    Are you just using it for on-set monitoring? Does it need to be color accurate?
    If you’re just using it for monitoring focus/composition or for rough preview then any HDMI compatible screen will work. Once you run your cable from the camera to the monitor though it’ll tie you down to that spot (fine for some type of productions….not viable for run ‘n gun shooters).
    If you need a color accurate monitor for on-set then you’re looking at spending quite a bit more, but you can have a look at FSI monitors, TV Logic, or Sony Professional monitors. With color accurate monitors you’re looking at a starting price of around $3K+.
    Ultimately, it really depends on your needs.
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Warren Eig
    August 14, 2014 at 4:33 pm
    Patrick,
    Check out the Swit s-1221 series (F, H) of 21.5″ monitors. I’m actually a reseller in Los Angeles. But I started as an end user with their 7″ for shooting. I liked them so much I asked if I could be a vendor.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
