Activity Forums VEGAS Pro Monitor Profiles – Spyder 3
  • Monitor Profiles – Spyder 3
    Posted by Steve Roberts on July 18, 2011 at 1:37 am
    Hi all,
    A few questions regarding color flow.
    I’ve calibrated my second vga lcd monitor using my Spyder 3 Elite which I use in Vegas to view video on.
    Question 1 – Do I load that ICC that the Spyder 3 has created into Vegas under the Preview Device preferences or has the windows system automatically loaded this profile thus making it system wide.
    I know that the system does load up the Spyder profile at start up but I was wondering if Vegas bypassed it.
    Question 2 – Along these lines should I be using the PAL/SECAM icc since I’m creating material for PAL DVD ?
    Question 3 – With regards to creating DVD material should I also be using the Computer to Studio Color Corrector to sit my material within the safe parameters. Note that I render out of Vegas to the final mpeg 2 files.
    Thanks for reading !
    Steve R.
    Amongst Projects
    ——— Sound, Visual and Electronic Content
    projects.amongstmyselves.com
    Malcolm Matusky replied 14 years, 10 months ago 3 Members · 6 Replies
  • John Rofrano
    July 18, 2011 at 11:46 am
    [Steve Roberts] “Question 1 – Do I load that ICC that the Spyder 3 has created into Vegas under the Preview Device preferences or has the windows system automatically loaded this profile thus making it system wide.”
    Yes, load the Spyder3 profile into the Vegas Secondary Display so that Vegas uses it.
    [Steve Roberts] “Question 2 – Along these lines should I be using the PAL/SECAM icc since I’m creating material for PAL DVD ?”
    No, use the one you created with the Spyder3. It will give you the most accurate color representation for your computer display.
    [Steve Roberts] “Question 3 – With regards to creating DVD material should I also be using the Computer to Studio Color Corrector to sit my material within the safe parameters. Note that I render out of Vegas to the final mpeg 2 files.”
    No, the footage you shot is already Studio RGB and the MPEG2 codec is also expecting Studio RGB so you already have everything set by doing nothing. You would only use the Computer RGB to Studio RGB filter on still images which are a computer RGB source.
    If you are worried about keeping broadcast safe levels, you should add the Broadcast Colors filter to your master video bus with the Lenient – 7.5 Setup preset applied. This will only clip the output however. You still need to monitor your levels with a Waveform monitor for luma values and Vectorscope for chroma values and keep them within limits. Otherwise the clipping may look very harsh.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Roberts
    July 18, 2011 at 12:36 pm
    Thanks for the great info John.
    But, an interesting point with regards to the studio rgb conversion. I should have mentioned that my footage is actually sequenced stills (timelapse) from various digital cameras. Does it still apply that I DONT need to do the computer to studio rgb conversion.
    Steve.
    Amongst Projects
  • John Rofrano
    July 19, 2011 at 1:31 am
    [Steve Roberts] “I should have mentioned that my footage is actually sequenced stills (timelapse) from various digital cameras. Does it still apply that I DONT need to do the computer to studio rgb conversion.”
    No, you need it. As I said in my previous post, “You would only use the Computer RGB to Studio RGB filter on still images which are a computer RGB source.” which means you SHOULD apply Computer RGB to Studio RGB to the image sequence because it was shot in computer RGB.
    ~jr
  • Steve Roberts
    July 19, 2011 at 1:48 am
    Sorry for not reading John – a little tired.
    Thanks for the confirmation.
    Steve R.
    Amongst Projects
  • John Rofrano
    July 19, 2011 at 2:38 am
    Don’t be sorry. Sometimes things aren’t as clear as we would like them to be. I’m always willing to explain again if it helps clarify one’s understanding. 🙂
    ~jr
  • Malcolm Matusky
    November 18, 2011 at 9:54 pm
    How does one load a profile into the secondary display? I have a 1 monitor system and cannot find the menu to do this? What am I missing?
    I do remember doing this in VP9, and now cannot.
    System:Win7 VP11
    Thank you,
    Malcolm
    Malcolm
    http://www.malcolmproductions.com
