Activity Forums Apple Final Cut Pro Legacy Monitor preview
  • Tom Meegan
    April 17, 2006 at 3:34 am
    For Mini-DV capture and edit, I would just use the easy set up.
    Final Cut Pro > Easy Setup…
    Then on the drop down choose DV NTSC or DV PAL. There are other variables for frame rate and aspect ration, but if you need those things, just choose those option.
    The easy setup will dial in all the variables for you.
    Monitor Preview
  • Michael Bayouth
    April 17, 2006 at 5:25 pm
    Thanks! That fixed it alright.
    I really appreciate it a lot.
    Michael
