Activity › Forums › Apple Final Cut Pro Legacy › Monitor not reading FCP
  • Monitor not reading FCP
    Posted by Conor Nyc on August 23, 2010 at 10:02 pm
    Hi!
    I am editing on Final Cut 7 and my monitor has stopped working with it. It still works on Color but not on FCP. I have a Kona 3 Card connected between them. The a/v settings are the same on both: Kona 3 1080p (1920 X 1080) 24p 10 bit.
    I have repaired permissions and deleted preferences but it still not regestering it. Any ideas? Perhaps there is something that has been something changed in its settings. I’ve tried everything and can’t think of anything else. I have also recently re-installed Final Cut Studio.
    Let me know! Thanks in advance.
    Conor Nyc replied 16 years, 1 month ago 3 Members · 4 Replies
  • John Fishback
    August 23, 2010 at 10:14 pm
    Check the View Menu > External Video should be All Frames.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Conor Nyc
    August 23, 2010 at 10:27 pm
    Thanks for your reply John but it does say this…
  • Victor Perez
    August 24, 2010 at 3:01 am
    You can Refresh A/V Devices under the View Menu.
    Check FCPs Video Playback and Audio Playback settings in Audio / Video Settings.
    The output from FCP corresponds with the input of the Kona out to your monitor.
    good luck,
    Victor
    http://www.editvictor.com
  • Conor Nyc
    August 24, 2010 at 2:37 pm
    Cheers guys. I have tried all this. It still isn’t working. The mystery remains…
