Activity Forums Apple Final Cut Pro Legacy monitor from EX3
  • monitor from EX3
    Posted by Salah Elfalahi on October 11, 2010 at 9:03 pm
    Hi all;
    How to monitor out from EX3 to SD LCD Monitor (AV in). I used to do that with Z5. the connections in EX3 are deferent than Z5. is there a cable SDI to AV ? or convert the component out cable that comes with EX3 to AV in !?
    Salah
    Kevin Knutson replied 15 years, 10 months ago 3 Members · 2 Replies
  • Craig Sommerer
    October 12, 2010 at 12:19 am
    Have you consulted the EX3 user manual at all? If I recall correctly, having last used the EX3 several years ago, the manual was very comprehensive as to various signals available in the monitor outs. If you don’t have the manual, I believe one is available on the Sony website.
  • Kevin Knutson
    October 12, 2010 at 10:52 pm
    You can use the “monitor out” BNC connection, found just next to the DC power. Might have to convert from BNC to RCA if your monitor doesn’t have the BNC.
