Activity Forums DSLR Video monitor for DSLR focus – the Goldilocks Solution
  • monitor for DSLR focus – the Goldilocks Solution
    Posted by Bob Cole on January 31, 2012 at 2:25 pm
    I’m looking for a compact, lightweight monitor for hand-held videography with my Canon 60D. I currently use the Zacuto Pro on the camera’s LCD, which works, but the limited resolution of the camera’s screen makes it quite challenging to maintain critical focus of moving subjects at wide apertures.
    For most applications, the Zacuto Pro is fine. But for those low-light, wide-aperture occasions, I need a slightly bigger monitor. I don’t want to trick the camera out with an elaborate shoulder brace, so I’m looking for a monitor that is just big enough. I like the 6.5″ 1024×768 pixel Marshall V-LCD651STX for tripod-mounted work, but for handheld, I’d prefer something smaller.
    I’ve tried to learn about the SmallHD line. The resolution of the SmallHD DP4 looks a little too low at 800×480, but I’m concerned about the size of the DP6.
    Focus and Framing – that’s all I want. The monitor could be black and white for all I care, as long as it’s as light and small as it can be, while getting the job done.
    Including the battery, what do you think is the Goldilocks solution for a monitor for a handheld DSLR?
    Bob C
    Darin Griffith replied 14 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Rick Diamond
    February 1, 2012 at 12:12 am
    Bob, take a look at the Ikan monitors. Both the 5.6″ (V5600) and 7″ (VH7E) have 1024×600 resolution. The 7″ is newer and less expensive and has more bells and whistles.
    Rick
  • Jason Jenkins
    February 1, 2012 at 5:19 am
    Bob,
    I’ve used the SmallHD DP6 mounted on top of my GH2 while handheld. It actually worked out quite well to use it with the neoprene sunhood attached. I could squish my face into it comfortably and it added stability while blocking out extraneous light.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
  • Bob Cole
    February 1, 2012 at 6:36 pm
    Thanks Rick, Jason.
    Another aspect to this question is that many DSLRs (e.g. Canon 60D, 5D Mark II) will downsize the HDMI output when the camera starts recording video.
    So one more criterion is whether the monitor will automatically recognize the downrezzing, and resize the image, when the HDMI output changes.
  • Jason Jenkins
    February 4, 2012 at 4:20 pm
    [Bob Cole] “So one more criterion is whether the monitor will automatically recognize the downrezzing, and resize the image, when the HDMI output changes.”
    Bob,
    Small HD has some great videos on that very subject. Here is one:
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jason Jenkins
    Flowmotion Media
  • Mike Thomas
    February 4, 2012 at 6:58 pm
    For my last film I used a Zacuto EVF with my GH2. The EVF has a digital zoom focus assist feature. Through the use of a homemade bracket and an old manual shutter release cable I was able to rig it up so that I could quickly and easily trigger the focus assist with my right hand finger while keeping my left hand on the lens. It worked great.
  • Brent Dunn
    February 9, 2012 at 6:51 pm
    check out the monitors at lcd4video.com
    I use a 7 inch monitor on top of my DSLR when tripod mounted.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
  • Darin Griffith
    February 10, 2012 at 4:35 pm
    I’ve been using the Ikan V5600 5.6″ LCD Monitor for a while now and it has helped immensely with focusing issues. I shoot with a Pana HMC-40 and Canon 7D. The monitor has 1024×600 resolution, which isn’t as high as I would like, but it is much better than the tiny built in LCD monitors on camera. It can run from the AC adapter or battery and has HDMI input so it works with my camcorder and DSLR which it is pretty handy/versatile.
