Activity Forums Apple Final Cut Pro Legacy Monitor Colour Setting
  • Monitor Colour Setting
    Posted by Francis Hughes on November 28, 2008 at 8:02 pm
    Hi All,
    Im mostly editing stuff for web here and had a quick question about the colour display profile for my MB G4. A friend of mine claiming he knew what he was doing changed it to Colour Match RGB from the standard generic profile. I happened to need to load my current fcp project on to a different computer and noticed that all the footage looked washed out. What if any setting should my screen be on, or should I add this to a list of things I dont believe exist (easter bunny, Tom Cruise etc).
    Cheers!
    Francis Hughes replied 17 years, 9 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    November 28, 2008 at 8:18 pm
    You can setup the computer’s display using Apple’s display prefs, but you should never judge the quality of anything on a computer display. Need to be looking at it externally on a calibrated video monitor to see what you really have going on there.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Francis Hughes
    November 28, 2008 at 9:46 pm
    Cool thanks Jerry. Of course you are totally right, however its for web and its going to be a 480×270 flv so a proper monitor is not really need for me as people watching the video will just be watching it on a screen like mine. Mainly I just didn’t want it looking totally washed out.
  • Jerry Hofmann
    November 29, 2008 at 6:27 pm
    Keep in mind that folks using a PC to view it are using a different gamma… usually what looks OK on a Mac screen is too dark on a PC screen so might want to raise the gamma up to about 2.2 from mac’s standard 1.8.
    That’s one reason to use H.264QT instead… it senses what is accessing it PC/Mac, and makes the adjustments automatically. Nice if you don’t have to have flv’s…
    Jerry
  • Francis Hughes
    November 29, 2008 at 8:31 pm
    Thanks Jerry, thats what I was after! Sadly I do need to do flv’s at 400kbps (roll eyes) yes I know such a heavy compression. Speaking of H.264 I read that if you export as that and simply change the extension to flv it should play in a flash player. I have no way to test this but is this something you have heard of?
    Many Thanks
    Francis
