Activity › Forums › Apple Final Cut Pro Legacy › Monitor Calibration out of FCP
Posted by Scott Davis on February 15, 2010 at 10:47 pmAnyone know an easy way to calibrate a monitor without a blue gun out of FCP?
Scott
OSX 10.5.5
Quad 2.5Ghz
8.5 GB RAM
Final Cut Studio 6.0.4
HPX 2000Scott Sheriff replied 16 years, 6 months ago 5 Members · 6 Replies -
Shane Ross
February 15, 2010 at 11:05 pmConnected via? What kind of monitor? If it lacks the proper controls, this will be challenging. People have suggested using a blue filter…but I’m not sure as to what the number of that filter is.
Shane
Read my blog, Little Frog in High Def -
Michael Sacci
February 15, 2010 at 11:07 pmWhat type of monitor and is the source from a video card (not graphic card) there are blue filters that you can look through to give you a blue gun effect. I even have a pair that are like the cheap 3D paper glasses. I used them on a Standard TV way back when, before I got a grade 1 CRT. It the TV to an okay place for casual CC.
https://www.costore.com/thx/productenlarged.asp?peid=87&pid=930793
Scott Sheriff
February 15, 2010 at 11:56 pmHave a look at the Matrox MXO.
Scott Sheriff
Director
SST Digital Media
https://www.sstdigitalmedia.com -
Shane Ross
February 15, 2010 at 11:59 pm[Scott Sheriff] “Have a look at the Matrox MXO”
That only works if the monitor you are trying to calibrate is a DVI computer monitor.
Shane
Bj Ahlen
February 16, 2010 at 12:26 am[Shane Ross] “I’m not sure as to what the number of that filter is.”
Wratten 47B, aka SMPTE Blue.
A Lee 3″x3″ 47B polyester filter is about $14 at B&H or Filmtools.
For procedure, see for example https://hd-cinema.blogspot.com/2008/06/hd-monitor-calibration.html.
Scott Sheriff
February 16, 2010 at 1:17 amShane,
Yes, your right! I made a presumption that (using Cinema display) is what was going on here. MXO2 has a blue only, that might work. Might not be as good as a calibrated monitor, but better than nothing.Scott Sheriff
Director
SST Digital Media
