Activity Forums Apple Final Cut Pro Legacy Monitor Calibration
  • Monitor Calibration
    Posted by Micki Wells on May 24, 2009 at 2:36 am
    Hi Everyone,
    I am a newbie just starting with FCP and I have bought 2 second hand 20″ Apple Cinema monitors that I want to calibrate. Can anyone suggest a good calibration tool they have had experience with as I am at a loss to decide which to buy. Any help would be appreciated.
    Cheers Micki
    Dale Thompson replied 17 years, 3 months ago 3 Members · 5 Replies
  • Rafael Amador
    May 24, 2009 at 10:10 am
    Hi Micki,
    I think you should use the Monitors Control Panel to adjust your Apple 20″.
    This is not a broadcast monitor that you have to adjust with bars or other test signals to work with.
    Rafael
    http://www.nagavideo.com
  • Micki Wells
    May 25, 2009 at 10:12 am
    Thanks so much for your advice Rafael,
    I will just relax now and concentrate on learning the program as it is one less thing to complicate my life with.
    thanks again!
    Cheers Micki
  • Rafael Amador
    May 25, 2009 at 1:12 pm
    Hi Micki,
    Soon you will start to feel the need of color correcting your movies. Then you will need a montor properly calibrated.
    Now read and practice as much as you can.
    Cheers,
    Rafael
  • Micki Wells
    May 26, 2009 at 5:39 am
    Hi Rafael,
    When the time comes to properly calibrate my monitors what are your suggestions for doing this?
    Thanks again
    Cheers Micki
  • Dale Thompson
    June 8, 2009 at 5:47 pm
    Mikki:
    Send me your email address and I will send you some material for calibrating your own monitors. I’ve heard that studios get professionals to calibrate their screens once every month or so (maybe that’s overkill too) and if you can afford it, it’s the best way to get it as close to perfect as possible. Usually, it’s like $100 for this service but I’ll show you how to do it for free for now.
