Activity Forums Canon DSLR Cameras Monitor 7D
  • Monitor 7D
    Posted by Lewis Wood on June 29, 2011 at 10:47 am
    Hey I’m struggling to find some answers here. I’m shooting a project on a 7D, and I need to use an external monitor for director and continuity to look at. However I want the internal monitor on the 7D to continue to function when using the external monitor.
    I’ve tested this out on a 5D using both the hdmi port and the composite port but have had no luck trying to get both monitors working at once.
    Could anyone shed any light onto the matter?
    Thanks in advance
    Brent Dunn replied 15 years, 1 month ago 3 Members · 2 Replies
  • Stevo Chang
    June 30, 2011 at 12:51 am
    Hmm… Yeah, i think the moment u utilize the composite/HDMI port, it automatically shuts the onscreen monitors off…
    If you need a 2-monitor solution, u could always get an HDMI splitter which splits the HDMI signal into 2 outputs – thus letting u attach a second monitor to the solution.
    Unless… I can’t remember WHERE i saw it, but someone rigged a video tap from their 5D’s eyepiece which left the on-board monitor “on”… but it was a custom build, so I don’t know where to purchase it…
    Jag35 sells a pretty cheap HDMI-splitter – altho i’ve never personally used it:
    https://jag35.com/index.php/hdmisplitter.html
    If you need portable power, they also sell a portable battery pack for it, altho its AA and not lithium-ion:
    https://jag35.com/index.php/hdmibattery.html
    Hope this helps?
    Director | Writer | DP | VFX Sup |
    Aspiring Carpenter | Unintentional 1-man Crew
  • Brent Dunn
    July 6, 2011 at 9:14 pm
    You cannot monitor and view the source from your. Camera. The hdmi cancels the signal. Keep the monitor close to the camera so you can see the monitor as well as the client and dierectie.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
