Activity › Forums › VEGAS Pro › Momentary Key command to disable ripple?
  • Momentary Key command to disable ripple?
    Posted by Brad Leigh on October 3, 2013 at 10:28 pm
    Does anyone know if it’s possible to program a momentary keyboard command to disable ripple. Same way you can momentarily disable snap?
    It would be so nice to leave ripple on, but when I didn’t want it hold tab or a key that I could program in the shuttle pro to disable. It would be so nice to know it’s on unless I was holding the key. Would love it.
    I always forget where I left it, and either have to look away from the time line before every edit or do a lot of control Z 🙂
    Brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
    Malcolm Matusky replied 12 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Stephen Mann
    October 4, 2013 at 2:40 am
    I wish that Ripple would always turn itself off after it’s use. I only turn it on when I need ripple, which is pretty rare, then I turn it off.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Brad Leigh
    October 4, 2013 at 3:40 am
    I rarely use it as well. I’m finishing a project that’s a bit long,so I’ve been tighting a bunch of edits. I really mis-stated my problem. I would like ripple off unless I press a momentary key.
    glad I’m not the only one.
    Brad
  • Stephen Mann
    October 4, 2013 at 4:30 am
    Press once, then Ripple is on. Then it’s off.
    Vegas already knows when something has changed – make any change, no matter how tiny or trivial, and the * next to the save icon comes on. Vegas could just as easily turn ripple off.
    Steve Mann
    http://www.mmdv.com
  • Graham Bernard
    October 4, 2013 at 11:25 am
    [Brad Leigh] “I always forget where I left it, and either have to look away from the time line before every edit or do a lot of control Z :)”
    _______________________________________________________________
    You and me both – G
  • John Rofrano
    October 6, 2013 at 11:51 am
    [Brad Leigh] “I would like ripple off unless I press a momentary key.”
    Use Ctrl+F after the edit. In other words, work with Ripple Off (as you should) and then when you make an edit and say, “darn I wish I had ripple on”, press Ctrl+F and Vegas will ripple the last edit “after the fact”.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    October 7, 2013 at 1:06 pm
    Thanks for the reminder, John. I never tried that shortcut but I will on my next project.
    Steve Mann
    http://www.mmdv.com
  • Brad Leigh
    October 7, 2013 at 2:34 pm
    John
    that is great to know. I’m going to program cntrl f to a unused key on my shuttle pro.
    thanks
    Brad
  • John Rofrano
    October 9, 2013 at 12:25 am
    [Brad Leigh] “that is great to know. I’m going to program cntrl f to a unused key on my shuttle pro.”
    That’s a great idea. The Shuttle Pro is great for this kind short-cut.
    ~jr
  • Malcolm Matusky
    October 9, 2013 at 9:33 pm
    Control L turns ripple on and off.
    Malcolm
    http://www.malcolmproductions.com
