Activity › Forums › Maxon Cinema 4D › Molecule grid
Molecule grid
Posted by Ari Grunzeweig on August 11, 2017 at 7:56 pmHi,
Can anyone guide me on how to recreate some like in the attached screenshot.
I imagine there is a solution within the cloner object, but I’m having lots of trouble figuring it out.Thanks!!
AriSteve Bentley replied 9 years, 1 month ago 3 Members · 5 Replies -
Brian Jones
August 12, 2017 at 3:58 pmit’s hard to see with only the one view, you can get semi close with a Grid Array 5x5x5 with a sphere and a null as children of the cloner (set it Iterate, the default)
Cloner
—Sphere
—Nullbut that’s only semi-close, it probably needs a combo of cloners
Ari Grunzeweig
August 12, 2017 at 8:33 pmHi and thanks. That does indeed get pretty close.
Then I’m trying to use the MoGraph > Tracer to connect the spheres, but it connects in a bizarre pattern.Is there a way to connect all spheres between them?
Ari -
Brian Jones
August 13, 2017 at 7:09 pmyou’d need a tracer with a distance parameter – there have been a couple in the past but none that I have now (don’t know if that’s because they stopped working due to version changes or if I just haven’t needed one and haven’t kept up) and given the construction I don’t know if the distance method would work either. I played with it for a bit and I think this is it, maybe fewer cloners are possible… 11596_moleculegridtrial.c4d.zip
Steve Bentley
August 14, 2017 at 4:03 amYou could also just make a spline the shape you want one layer to be with points on the spline where each sphere goes. Put that spline (or splines) in a cloner and have it generate all the layers – then collapse that cloner with make polygonal. Then use the atom array on the resutling objects and just make the spheres bigger than the tubes.
