Activity › Forums › Avid Media Composer › Mojo Workaround?
  • Mojo Workaround?
    Posted by Christopher St. john on February 24, 2010 at 7:29 pm
    Hello,
    I’m working with a mac-based, software-only media composer system which for my general purposes works great. However, I’ve just come across a large pile of old Beta tapes that I need to capture for a project.
    Assuming that I don’t care much about video quality for the offline edit, and just want to digitize the material with original timecode as place holders, is there a less expensive option than purchasing/renting a mojo box?
    Any help is much appreciated.
    Chris
    Kris Anderson replied 16 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Michael Hancock
    February 24, 2010 at 8:05 pm
    Nope. The old Mojo with component cables is your cheapest options.
    Unless you can find a Beta deck with firewire out (do they even exist?). Then you could capture via firewire, so you wouldn’t need a Mojo.
    Michael Hancock
    http://www.oswaldcommunications.com
  • Michael Mcintyre
    February 24, 2010 at 8:30 pm
    You could take it through a DV camera. That assumes you could get deck control independently of firewire. You’d also be stuck with audio being piggyback’ed on the DV stream. So it’d be XLR->RCA to get into the DV cam.
    My Mojo went down briefly years ago and we HAD to go through a Canopus ADVC110. Not ideal but it works.
  • Mark Spano
    February 24, 2010 at 9:13 pm
    [Michael Hancock] “Beta deck with firewire out (do they even exist?)”
    Yes – the J-30 machines from Sony will play BetaSP and have a firewire out. Haven’t tried using it for deck control, but the signal is there…
  • Michael Hancock
    February 24, 2010 at 9:23 pm
    Good to know.
    If you can find this deck you could run the firewire signal into your system for the video and audio and get a Keyspan adapter for the Mac for deck control (if you can’t control it via firewire). A quick online search shows they rent for about $200/day. May be cheaper to buy the Mojo if you need it for a few days.
    Michael Hancock
  • Christopher St. john
    February 24, 2010 at 10:25 pm
    Thanks all, greatly appreciated. I checked out the J-30 but seems more cost-effective to pick up an older mojo – seems they’re available on ebay for under $500. I’ve got at least a couple days (probably a few) of footage to capture.
  • Michael Hancock
    February 24, 2010 at 11:11 pm
    I think the stars are aligning in your favor. This just posted today on DVXUser:
    https://www.dvxuser.com/V6/showthread.php?t=201142
    Mojo for $400.
    Michael Hancock
    February 24, 2010 at 11:27 pm
    Great tip, thanks!
  • Kris Anderson
    February 24, 2010 at 11:30 pm
    J-30 with firewire for sure.
