Activity › Forums › Avid Media Composer › MOJO SDi effects
MOJO SDi effects
Posted by Don Logan on December 21, 2006 at 6:40 amDoes anyone know what extra Avid effects you get when you use the SDi Mojo running on Newscutter or Media composer?
Thanks.
Oakmozart replied 19 years, 9 months ago 4 Members · 5 Replies -
Martin Kraut
December 21, 2006 at 11:30 amThe Main features from mojo are only the possibility to edit /Preview material (eg.1:1/2:1 etc)in realtime.
When you buy a mojo box there are no extra or separate effects in the package.Effect Packages are direct integrated into the software component you are using.Have a look ate FAQ-Page
https://www.avid.com/products/dna/mojo/faq.asp -
Don Logan
December 22, 2006 at 5:29 amThanks for the info, I wasn’t sure as I know that with the Adrenaline you get the paint effect, animatte, spectramatte. I was hoping that these would be unlocked on the Mojo as well.
thanks
Dan L.
December 23, 2006 at 9:34 pmAnimaate and Spectramatte come with Th MCsoft application.
Best,
D
Don Logan
December 23, 2006 at 9:37 pmCool, thanks for the info. Can or will have access without a Mojo? Also do you know if the paint effect is included?
Happy holidays
Oakmozart
December 27, 2006 at 12:39 amPaint is only included in Media Composer software and higher. It’s not in Xpress Pro or lower. Keep in mind that Mojo and Mojo SDI can be used with either Xpress Pro or Media Composer software. Adrenaline is simply the hardware that’s a step-up from Mojo and powers the Media Composer Adrenaline system. In other words, Media Composer Adrenaline = Media Composer software + Adrenaline Hardware.
Hope that helps.
