Activity Forums Avid Media Composer Mojo for film project
  • Mojo for film project
    Posted by Danny Shik on June 27, 2006 at 5:14 pm
    Hi everybody
    Do I really need a Mojo in order to digitize and edit a movie shot at 24 fps and transferred to tape at 25 fps pal. The sound I get on files with a 25 fps TC.
    My system is Express Pro HD 5.2.
    I understand that my project should be a 24p pal, as such the capture option is not available.
    I was told that my only option is Mojo. Is that true?
    Thank you
    Danny
    Michael Phillips replied 20 years, 3 months ago 2 Members · 1 Reply
  • Michael Phillips
    June 27, 2006 at 7:35 pm
    Pal Method 1 for 24p should be possible without a Mojo. It is the playback back out when audio is sped up or not depending on output rate (24fps/25fps) that requires a Mojo. If you do the whole project as 25p, then no Mojo is needed.
    Michael
    anything 24fps
