Mojo DX and SDI Loop-through to Component
Hey there. I’ve been tasked to upgrade a system for a training center. They have an Avid Mojo DX and MC 3.5. There is also a ProTools system and FCP on separate boot drives. Their monitor is an PVM 20m4U without the SDI card and they also have a Sony DSR 2000 DVCam deck.
I set up the Mojo DX to feed SDI to the the deck and then used the component output to feed the monitor. The deck has a signal generator and bars hit the monitor from component and composite (Super) out. No such luck from the Avid. Either the signal is not coming out of the Avid in a correct format or the signal out of the Mojo is not reaching the deck.
Avid Mojo and deck are also getting blackburst from generator. The flashing indicator on the Mojo is SD_SDI indicating a bad input signal….There is no input attached, everything else is locked. The card is in the 4th slot.
When I switch the input on the DSR 2000 to SDI it doesn’t show anything but black. I know the monitor is hooked up right.
Is there any way to test the output of the Avid? I’ve tried switching users/projects etc…30i 24 p 1080, etc…nothing out of the Avid. Strange….I must be forgetting something really simple. Anybody have a clue?
Mitch Jacobson
Producer/Editor Avid & FCP
New York City
