Activity › Forums › Adobe After Effects Expressions › MOGRT make selected words in italics
  • Manuel Moellmann
    January 16, 2023 at 11:17 pm
  • Yoan Boisjoli
    January 17, 2023 at 2:16 am
    Thanks Manuel! This is amazing. Just need to figure out how to use it now hahaha
  • Sarah Bartels
    March 21, 2023 at 8:46 am
    Quick and dirty:
    – CONTROL Layer with two sliders (ITALIC IN & ITALIC OUT)
    – Animator on the Text Layer with Skew 22
    – Advanced: Based on Words
    – Expression / Range Selector:
    Start: thisComp.layer(“CONTROL”)(“Effects”)(“ITALIC IN”)(1);
    End: thisComp.layer(“CONTROL”)(“Effects”)(“ITALIC OUT”)(1);
    Now you can use the sliders to set the words that should be in italics 😉
  • Yoan Boisjoli
    March 21, 2023 at 10:03 am
    Hi Sarah! Thanks for the reply! Yes the skew method works well. The problem I had was that I needed to be able to select multiple words.
    What I do now is use a code Dan Ebert wrote a while ago. Basically, I have the words encapsulated in square brackets [] be italic and the words in curly brackets {} be bold. I’m using the dirty skew and stroke method.
