Activity Forums Adobe Premiere Pro Mogrt error and revision
  • Mogrt error and revision
    Posted by Kathi Beasley on June 2, 2019 at 6:36 pm
    I was recently involved in a project using mogrts. At the end of the day, it was discovered that a typo existed in a lower third that had been edited throughout a 24 minute program. Is there a way to globally change the mogrt quickly without having to highlight each section on the timeline and make each change separately? There was quite a bit of panic to make the deadline using the second more lengthy method.
    Kathi Beasley replied 7 years, 2 months ago 2 Members · 2 Replies
  • John Heiser
    June 14, 2019 at 3:55 pm
    As you’ve probably noticed from the lack of responses, the answer is “no.” There’s no global method of changing elements in graphics clips. It would be great, though, especially if it’s a MOGRT created in AE, to be able to correct it in AE, overwrite it in Essential Graphics, and have that change update dynamically.
    John Heiser
    Senior Editor
    o2 ideas – Birmingham, AL
    iMac Retina 5k, 27-inch, 2017
    4.2 GHz i7, 32GB RAM, Radeon Pro 580 8GB
    G-Speed Studio TB-2 12TB RAID-5
  • Kathi Beasley
    June 14, 2019 at 7:16 pm
    Thanks John.
    Adobe should definitely put that on its list of needed updates.
