Activity › Forums › Adobe After Effects › MOGRT – Constrain to two specific fonts, can it be done?
  • MOGRT – Constrain to two specific fonts, can it be done?
    Posted by Cornilla Bro on September 17, 2026 at 1:50 am
    Hello,
    Wondering if anyone knows if I can limit font selection when creating a MOGRT?
    ie I only want the user to be able to select from two font choices.
    Corn
    Cornilla Bro replied 1 week, 3 days ago 3 Members · 3 Replies
  • Chris Voelz
    September 17, 2026 at 2:24 am
    You should be able to limit it via expressions, and then use a checkbox in the mogrt settings to control it. Probably want to limit it to system fonts, otherwise you’ll get some funky results.
  • Dan Ebberts
    September 17, 2026 at 10:05 pm
    Here’s a simple example. Try adding a checkbox to your text layer and add this expression to the Source Text property (edit the font names to ones that make sense on your system):
    cb = effect("Checkbox Control")("Checkbox").value;
    cb ? style.setFont("ArialMT") : style.setFont("LucidaConsole");
  • Cornilla Bro
    September 17, 2026 at 10:28 pm
    Thanks so much for your help! I ended up finding this really helpful tutorial, once I realised it was possible from your replies: https://www.youtube.com/watch?v=xwx7W71dSr4
