Activity Forums Adobe Premiere Pro Mograph with Interpolated Media Replacement
  • Mograph with Interpolated Media Replacement
    Posted by Delio Goncalves on November 26, 2025 at 7:26 pm
    Hi, I currently work at a broadcast company and I’m trying to create a MOGRT in After Effects to use in Premiere Pro. It consists of a motion-graphics sequence with video and editable text. The text works fine, and I can replace the media (video), but I’m having a problem with interlaced footage (50i). The video doesn’t play correctly — it seems like it’s being rendered with the wrong frame interpolation. Is there an option I need to enable or change to make interlaced video work properly? Or simply mograh doesent suport interlaced footage?
    Best regards.
    Roland R. kahlenberg replied 9 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    November 27, 2025 at 2:50 pm
    You can’t access composition settings to work automatically with a MoGRT.
    If you need a MoGRT to be used in different frame sizes, frame rates and with interlacing, you have to set up the MoGRT accordingly in AE.
    In AE, each ‘final’ composition is placed into a composition which will be exported as a MoGRT. In this composition, you create a Drop Menu for the user to select which nested composition they want to work with. You will link each nested composition’s opacity to the Drop Menu so that only 1 nested composition has Opacity = 100% from any selection. And this composition should also be the sized to the largest output requirement amongst the different outputs because Premiere will just display each MoGRT centrally.
    It’s a bit cumbersome because you will have to link the text inputs centrally so that 1 change ripples through to all compositions. And this too for the Replacement Media.
    HTH
