Activity Forums Maxon Cinema 4D MoGraph with bitmap sequence
  • MoGraph with bitmap sequence
    Posted by Simon Cam on July 18, 2008 at 2:37 pm
    Hello!
    I’m trying to put some bitmaps on some planes that are being cloned along a spline using a MoGraph cloner. Ideally I’d like to be able to use a “sequence” of images across the clones, so that the first object uses bitmap1, second uses bitmap2 and so on. Is there any way to maybe use the frames of a QuickTime as a texture to do this? BTW I’m a MoGraph newb!
    Any help much appreciated!
    Cheers, sCam
    Adam Trachtenberg replied 18 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 18, 2008 at 6:50 pm
    Yep, you can do this with the Mograph multishader. As best as I can recall, you load the .mov file in the first slot, then click the “convert to layers” (or similar) button. Takes a while to process depending on the size of the file.
