Activity Forums Maxon Cinema 4D mograph textures
  • mograph textures
    Posted by John Jinks on October 10, 2008 at 3:33 am
    I’m trying to flip a textured plane broken up in tiles with a cloner and a plain effector . Is there a way to color the front and back with different textures? I’m using quicktime movies as the texture? I basically want the front to be one image (movie) and as it flips over be the other image(movie).
    Thanks in advance
    John Jinks replied 17 years, 11 months ago 2 Members · 2 Replies
  • Randy Johnson
    October 10, 2008 at 5:52 am
    In the texture tag under the projection type there is an option called “side”. It is defualted to “both”. Put two texture on your plane and set one texture to front and the other to back.
    /randy
  • John Jinks
    October 10, 2008 at 1:21 pm
    Thanks for the reply. After using mograph a bit more I found what worked.
    Apply on the left most material tag Frontal projection and side as front then on the next material
    have the projection be flat with front as well. Works foe me.
    Thanks again.
    J
