Activity Forums Maxon Cinema 4D MoGraph Text Objects won’t Motion Blur
  • MoGraph Text Objects won’t Motion Blur
    Posted by Joe Vandalsem on April 15, 2009 at 6:55 pm
    Hi, I’m using C4D 11, but also have access to 10 if it would help.
    I can not get the text objects to render with motion blur no matter what I do, i can insert a cube into the same scene with the same motion blur tag, and the motion blur effect and vector motion blur effect enabled, along with the vector motion post effect enabled, and the cube will blur, but none of my text will. Seems everything but text objects render with motion blur.
    There must be something I’m doing wrong, does anybody know how to correct this? I really do not want to use AE to do the motion blurs, as these graphics will be stereo and I want to have the correct perspective and have them consistent from eye to eye.
    Please help!
    Thank you!
    -joe
    Adam Trachtenberg replied 12 years, 1 month ago 3 Members · 5 Replies
  • Adam Trachtenberg
    April 15, 2009 at 7:47 pm
    That is curious — not sure if it’s a bug or limitation.
    You’ll have to use scene motion blur if you want to do it in Cinema. Slow, but better quality.
  • Felipe Mendoza
    August 13, 2014 at 8:40 pm
    I regret to tell you that Motion Blur is giving me lot’s of weird reactions with Mograph.
    Vector Motion Blur does a poor job, and Scene is making the MoText change position!
  • Adam Trachtenberg
    August 14, 2014 at 3:58 am
    Did you cache it before rendering?
  • Felipe Mendoza
    August 14, 2014 at 4:07 am
    Nope. How do you cache before rendering?
    I’m fairly new to Cinema, so I would really appreciate if you can help me with that 🙂
  • Adam Trachtenberg
    August 14, 2014 at 6:32 pm
    You can cache mograph by adding a mograph cache tag to your motext and then clicking the “bake” button.
    That said, I don’t see any problems here using motion blur with baked or unbaked motext animation.
