Activity Forums Maxon Cinema 4D MoGraph Text Object Material Projection
  • MoGraph Text Object Material Projection
    Posted by Chris Hiatt on February 25, 2010 at 11:12 pm
    Just wondering….
    Is there any way to use a Mograph Text Object with an effect like a Step Effector and have the Material not slide? It seems that the only way I can get it to work is if I make my text editable. I’ve tried the “Stick Texture Tag” and that doesn’t seem to work either. I am on C4D R11. Thanks. chris
    Corrado Carlevaro replied 16 years, 5 months ago 3 Members · 2 Replies
  • Sven Meyer
    March 23, 2010 at 3:10 pm
    Anyone found a solution for this? I got the same problem and can’t find a solution!
  • Corrado Carlevaro
    March 30, 2010 at 12:56 pm
    I have the very same problem, there are lot of posts about sticking textures but they don’t seem to solve that simple problem: a Mograph Text Object which texture (i.e. flat projected) doesn’t “slip” when the text is animated with effectors. Did you find a solution?
    Corrado
