Activity Forums Maxon Cinema 4D Mograph + Spline Effectors
  • Mograph + Spline Effectors
    Posted by Tom Slattery on October 29, 2008 at 7:25 pm
    Hi!
    I am trying to animate arrows running along a path while having them bend to it’s shape. I have been able to wrap a single arrow using a Spline Wrap. I can also clone multiples using a MoGraph Cloner + Spline Effector. Problem is with the cloner, the arrows stay rigid while they travel along the path. I am trying to combine the two effects to make them not only clone and move along the path, but bend with it. Hopefully that makes sense.
    ~TPS
    Adam Trachtenberg replied 17 years, 10 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    October 29, 2008 at 10:31 pm
    I don’t think you can actually do that with the Cloner. What you could do is copy your spline-wrapped object as many times as you need to and then use some expresso to control the the relative offset of the objects.
  • Brian Jones
    October 30, 2008 at 5:01 am
    This might work. Animate Offset in the SplineWrap
  • Tom Slattery
    October 30, 2008 at 1:38 pm
    That did it! Looks like the step effector was the missing link.
    Thank you very much!
    ~TPS
  • Adam Trachtenberg
    October 30, 2008 at 2:56 pm
    [Brian Jones] “This might work. Animate Offset in the SplineWrap”
    I stand corrected. 🙂
