Activity Forums Maxon Cinema 4D mograph spline and volume effector issues
  • mograph spline and volume effector issues
    Posted by Steve Davis on June 16, 2010 at 6:49 pm
    hi guys, im just doing some tests with spline effectors.
    basically, i have a tube of spheres cloned (200) and im using a spline effector to sweep them over into some text which is a spline, so the text is now covered in spheres.
    the problem is i now want to sweep them off the text and use the 200 spheres to fill an object.. is this possible? i thought volume effector might be the right one to use but i guess its not. instead of dropping the spline tect into the
    any tips would be much appreciated.
    thanks in advance!
    james
    Adam Trachtenberg replied 16 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 16, 2010 at 7:50 pm
    The volume effect doesn’t do what you’re thinking it does. It just affects P/S/R of any object inside the volume.
    What I would do would is:
    * Create a matix object with the same particle count as your cloner;
    * Set the mode to Object/Volume and reference the geometry you want the clones to fill;
    * Apply an inheritance effector to move the clones from the spline to the matrix particles (make sure “morph motion object” is checked).
