Activity › Forums › Maxon Cinema 4D › Mograph Selection ‘hide selected’ resets when re-opening file?
  • Mograph Selection ‘hide selected’ resets when re-opening file?
    Posted by Mostyn Rowley on January 4, 2019 at 4:29 pm
    Using Mograph selection on a number of clones for trainers across a wall bay.
    Have no issues in adding the tag & selecting the clones to hide. ‘Hide selection’ works fine, but when i save the file & re-open all the clones are visible, as if the hide selection has been turned off. I can still select the tag & then add another ‘hide selected’ effector which hides the clones again, but the same problem arises once the file is closed & re-opened.
    Does anyone have any suggestions as to how to make sure the effector is remembered? Or am i missing a step somewhere?
    Mostyn Rowley replied 7 years ago 2 Members · 2 Replies
  • Emir Bojorquez
    January 6, 2019 at 1:17 am
    Works correctly for me in R19 and R20
    Try this one and see if it’s working:
    12997_test.c4d.zip
    If so, you could try to move all your scene to a new file and try again.
    Good Luck
    Imagination is the best tool…
  • Mostyn Rowley
    September 23, 2019 at 1:55 pm
    Sorry for the late response… never saw your reply..
    I think i was due an update, now running R20 & the issue seems to have resolved itself.
    Thanks for your help anyway!
