Activity › Forums › Maxon Cinema 4D › mograph: ripples on water fx with cloned tubes?
  • mograph: ripples on water fx with cloned tubes?
    Posted by Dflamholc on August 7, 2007 at 12:32 pm
    Hello,
    I tried to put it all in the subject. Basically I’m trying to make a graphic(!) representation of ripples on a water surface spreading after a water drop has fallen.
    Basically I’ve grid cloned a tube primitive, moving only 1 unit in each direction but giving it 10 instances, then with my first step effector scaling it along x and z axis and then animating my next step effector passing through the “plate” of scaled up tubes attempting to make them move on the y axis, thus creating a ripple effect. I just can’t make it work. when I approach the centre of the tube clone all the tubes move in exponentially in unison up or down, but not one at a time with falloff like a ripple should… i hope i’m being clear about what i’m trying to do. (it is not an outwardly growing radio-wave effect i’m looking for.)
    i’m on Cinema 4D 10.1 with mograph, obviously… 🙂
    i realise i might be looking at this from the wrong angle.
    any advice on how to do this would be immensely appreciated!
    many thanks in advance, david
    Adam Trachtenberg replied 19 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 13, 2007 at 9:59 pm
    I’m not able to picture what you’re doing with mograph, but is there a reason that you haven’t used the ripple shader?
