Activity Forums Maxon Cinema 4D Mograph Random Rotation Effector
  • Mograph Random Rotation Effector
    Posted by Joanpablo Torres on April 11, 2017 at 10:04 pm
    I have an object within a cloner. I added a random effector and set it to affect the position and rotation. These object are rigid bodies and are set to fall upon starting the animation.
    I would like to keyframe OR have the rotation change over time automatically. I try to keyframe, and it doesn’t work. I see the values change but the objects don’t move from their respective falls.
    What am I doing wrong? or how should I be doing this?
    Adam Trachtenberg replied 9 years, 4 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    April 12, 2017 at 1:42 pm
    If you go to the dynamics tag’s Force tab and increase the “follow rotation” setting, you’ll be able to influence the rotation of the dynamic objects with effectors. There’s no way to keyframe dynamic objects unless they’re just collider objects.
  • Joanpablo Torres
    April 12, 2017 at 6:38 pm
    Hmm, didn’t seem to work. Here’s the project file, what seems to be the problem?
  • Joanpablo Torres
    April 12, 2017 at 6:41 pm
    didn’t seem to do the trick, I know I’m doing something wrong. Here’s the file if you don’t mind taking a look at it.
    https://drive.google.com/open?id=0B_Lq-gczSsxVLWg4bE1UUDRtSjg
    R17
  • Adam Trachtenberg
    April 12, 2017 at 7:05 pm
    You need to set the random effector so the objects change rotation over time. One thing you could do is go to the effector tab and change the mode from random to noise. Then adjust the scale and animation speed (and rotation parameters in the parameters tab). Or you could animate the rotation settings in the parameters tab.
