Activity Forums Maxon Cinema 4D “MoGraph – Part I – Cloner” tutorial question
  • “MoGraph – Part I – Cloner” tutorial question
    Posted by Alex Kogan on January 30, 2009 at 4:21 pm
    Hello,
    MoGraph – Part I – Cloner is very nice and clear tutorial, except 1 thing i cant figure out.
    In the spline object part, cone (arrowhead) is moving along the spline, as the result of clone’s “end” parameter animation (at 15:06) – i cant make that work..
    Could anyone please help me with that?
    Alex Kogan replied 17 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    January 31, 2009 at 3:53 am
    The cloner with the pyramid should be simple enough. I suspect the tricks are:
    – the helix is used twice, once for the cloner – once for the arrow
    – he uses a spline tag for the Cone (Arrow) and animates the cone along the helix and matches the Align to Spline’s ‘Position’ parameter to match the Cloner’s ‘End’ parameter
    – set the Cone’s Orientation to +Z and Check ‘Tangential’ and set Axis to Z in the Align to Spline tag
    – the Helix should be set to Uniform (makes it easier to match the timing along the spline)
    Something like this
  • Alex Kogan
    February 2, 2009 at 10:57 am
    Thank you very much for reply
    I suspected that it animated separately, but thought that may be there is some trick to animate the arrowhead through the cloner start/end parameter.
