Activity Forums Maxon Cinema 4D Mograph: need the materials be on one side and not both
  • Mograph: need the materials be on one side and not both
    Posted by Ian Rajkumar on June 2, 2011 at 3:57 pm
    Hey Guys,
    I am making an animation in C4D using mograph, what I need to do is have one material/image on the front side of the 960×370 wall i made with small titles using mograph and then it is animated to break away and flip over to reveal the backside, and on this backside I need it to have another material/image
    The issue is, the material is applied to the entire wall, all over and not just front side or the backside.. i need the front image to be on the front and the back to be on the back
    can you guys help me out? ..thanks in advance
    see the zip file attached with the project file
    2423_flippingtiles.zip
    Craig Whitaker replied 15 years, 3 months ago 2 Members · 1 Reply
  • Craig Whitaker
    June 2, 2011 at 9:19 pm
    Two materials, flat projected, one set to back, one set to front. Try that and see if it’s what you need.
    Best,
    Craig
    craig whitaker
    vfx – mograph
