mograph grid with object?
I am looking to make a pin sculpture type thing and was told to use the mograph module. This works but the problem is i need the pins to stay in a grid and when i use the object effector the pins stick to the vertices or polygons etc.. The thing i need the pins to be effected by is a model from poser so you get a lot more pins around face etc..
Is there anyway around this
