Activity Forums Maxon Cinema 4D Mograph – generate clones from an image
  • Mograph – generate clones from an image
    Posted by Tim West on June 17, 2008 at 1:23 pm
    I am trying to use a material containing an image as a texture to generate clones – e.g. where the image is white clones are generated, where it is black they are not.
    Any ideas?
    Adam Trachtenberg replied 18 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 17, 2008 at 4:38 pm
    You can’t do this directly, but what you can do is use a shader effector (with the bitmap loaded) to affect visibility of the clones, which has the same effect.
