Activity › Forums › Maxon Cinema 4D › Mograph Dynamics Project Settings
  • Mograph Dynamics Project Settings
    Posted by Kevin Snyder on June 23, 2011 at 3:13 pm
    I am working on a simulation that needs the dynamics settings for my mograph project to work right. While reading the help documentation, it indicates that there is a setting in the expert tab of the dynamics project settings called “Restitution Lifetime for Resting Contact”. The documentation indicates that the setting should be located between “Scale” and “Random Seed”, but it is missing. Is this option excluded from the Broadcast version of R12? Thank you for your time.
    Kevin Snyder
    Kevin Snyder replied 15 years, 3 months ago 2 Members · 6 Replies
  • Adam Trachtenberg
    June 23, 2011 at 6:44 pm
    Do you see the Project Settings>Dynamics>Expert tab at all?
  • Kevin Snyder
    June 23, 2011 at 6:48 pm
    Yes, the expert tab is there…it’s just missing the “Restitution…” parameter. I see a Cache Tab and Visualization Tab exist according to the documentation, but they don’t show up. Do I need the R12 Studio to access everything? Thanks.
  • Adam Trachtenberg
    June 23, 2011 at 7:03 pm
    Hmm, I don’t know. I have studio here.
  • Kevin Snyder
    June 23, 2011 at 7:04 pm
    Do you see all the options that I have missing?
  • Adam Trachtenberg
    June 23, 2011 at 7:35 pm
    Yes, I have all the options.
  • Kevin Snyder
    June 23, 2011 at 7:59 pm
    Thank you for taking the time to look…I appreciate it.
