Activity Forums Maxon Cinema 4D Mograph Color Shader
  • Mograph Color Shader
    Posted by Craig Whitaker on May 15, 2012 at 4:09 pm
    Hi everyone,
    I have a scene where a shader effector is driving a color change between the clones transform color, and the color in the shading tab of the effector. My question is, can this setup utilize two material tags instead? Thank you.
    Best,
    Craig
    4145_colorchange.c4d.zip
    Craig Whitaker replied 14 years, 4 months ago 3 Members · 4 Replies
  • Brian Jones
    May 16, 2012 at 12:49 am
    what do you want to happen that is not happening now? Color fade from one color to the other or maybe you want to use images?
  • Craig Whitaker
    May 16, 2012 at 1:04 am
    I’m wondering how I could build two shaders with different spec, reflection, bump, whatever… And then “effector” between them. Thanks!
    Craig
  • Adam Trachtenberg
    May 16, 2012 at 2:05 am
    Put the mograph color shader in one of the material’s alpha channel and then stack that material on top of the other one.
  • Craig Whitaker
    May 16, 2012 at 1:32 pm
    Adam,
    Thanks so much, this is exactly what I was looking for.
    Craig
    craig whitaker
    vfx – mograph
    https://www.imdb.com/name/nm4117151/
