Activity Forums Maxon Cinema 4D Mograph cloner to spline?
  • Mograph cloner to spline?
    Posted by Ben Fallin on June 9, 2011 at 1:31 pm
    Hey all I’ve created a bolt in c4d it needs to be placed about 55 times all over an object. I’ve created a spline that goes through those locations and then used a cloner from mograph to clone the bolt, but how do I attach these clones to the spline? Thanks all.
    Randy Johnson replied 15 years, 2 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 9, 2011 at 1:36 pm
    From your description its sounds like a difficult way to add the bolts…. however to answer you all you need to do is change the Cloner Mode to Object and drag the spline into the link option that appears when you swap mode.
    /Randy
