Activity Forums Maxon Cinema 4D Mograph and visibility
  • Mograph and visibility
    Posted by Vicn on January 10, 2007 at 1:57 pm
    Hello all, I’m animating some text with the mograph module and want the letters to fade in over time, how can i do that? I’ve messed with the visibility option and step effectors but nothing seems to do the trick!!??
    Chris Smith replied 19 years, 8 months ago 3 Members · 4 Replies
  • Mylenium
    January 10, 2007 at 5:53 pm
    You need to use MoGraph’s Color shader in the transparency channel of your material.
    Mylenium
    [Pour Myl
  • Vicn
    January 10, 2007 at 8:27 pm
    Nice, will try. Thanks!
  • Vicn
    January 12, 2007 at 4:12 pm
    Arrgh. nope, cant figure it out. I’ve set put the color shader in the alpha channel of a material, put it on the text object and messed with it but can’t figure out how to make it do anything, and the manual doesn’t make me any smarter…
    Mylenium, do you cover this in your fantastic mograph tutorial? i must have missed it!!??
  • Chris Smith
    January 16, 2007 at 10:12 pm
    Don’t know if this solves it, but Mylenium said to use it in the transparency channel and not the alpha channel. You could try switching it.
    Chris Smith
    https://www.sugarfilmproduction.com
