Activity Forums Maxon Cinema 4D MoGraph 2 Dynamics problem
  • MoGraph 2 Dynamics problem
    Posted by Oliver Koch on December 28, 2009 at 12:53 am
    Hi guys,
    i’ll bet that most of you have already seen one ofthose examples for the new Dynamcis feature where many objects are attracted to a sphere with an attractor….i tried to do the same things with text, but it didn’t worked. (which means the text should be the thing the other objects are attracted to) Is there a possibility to give the attractor some kind of a shape, so it doesn’t appear as point?
    I hope some of you can get the point, cheers =)
    Oliver Koch replied 16 years, 8 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    December 28, 2009 at 4:35 pm
    It’s possible to set the attractor’s falloff to “source” and then drag a text object into the source box, but it doesn’t seem to have the desired effect. I think you’re going to have to use TP for this effect.
  • Oliver Koch
    December 28, 2009 at 5:52 pm
    Thanks mate!
    Actually, I’m still new to C4D, could you manage to give me a hint for setting up that system?
