Activity Forums Maxon Cinema 4D Mograph 2 – Can you turn off gravity?
  • Mograph 2 – Can you turn off gravity?
    Posted by David Wiffen on December 17, 2009 at 11:03 am
    Hi everyone,
    I’m creating a scene with a few balloons. I want to use rigid body collisions from mograph 2 to stop the balloons cutting through each other and add some nice controllable mograph animation.
    Problem is, I can’t seem to stop the balloons just falling to the ground. I’ve tried all mass settings with no improvement. I want them to have 0 mass or the scene to have 0 gravity.
    Is this possible in mograph 2?
    Many thanks in advance.
    David Wiffen replied 16 years, 9 months ago 3 Members · 3 Replies
  • Ronaldo Montalvo
    December 17, 2009 at 7:01 pm
    if you look under Edit/Project Settings/MoDynamics attributes tab, you can change the time scale to 0, keyframe it to 1 to start gravity back up. (project settings on the mac is command D.)
  • Adam Trachtenberg
    December 17, 2009 at 9:54 pm
    You can also set gravity to 0 in scene settings and use a particle gravity effector instead.
  • David Wiffen
    December 18, 2009 at 8:57 am
    Great thanks guys.
