Activity › Forums › Maxon Cinema 4D › MoDynamics Question
  • MoDynamics Question
    Posted by Justin Vennes on July 15, 2010 at 9:21 pm
    Hello All,
    MoDynamics Question
    I have a client that wants an animation similar to a Hula Hoop Backspin. I have a cylinder inside a cloner object that has Custom Initial Velocity set to +1200 in the x direction and a Initial Angular Velocity set to -900 in the B rotation field. This gives me the animation I want but the cylinder eventually starts to go off axis until it falls like a real hula hoop would (on to a floor plane). I am wondering if there is a way to keep the cylinder upright…ie not have the cylinder fall flat.
    Thanks for your help in advance.
    Justin Vennes replied 16 years, 2 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    July 16, 2010 at 4:27 pm
    I would increase angular damping in the force tab and increase the threshhold settings in the dynamics>deactivation section. The first change will cause the rotation to slow faster (huh?) and the second will turn off dynamics when the motion reaches the set velocity.
  • Justin Vennes
    July 16, 2010 at 10:17 pm
    Fantastic! Thank you.
