Activity Forums Maxon Cinema 4D modynamics – 2 objects colliding, both smashing
  • modynamics – 2 objects colliding, both smashing
    Posted by Simon Robson on March 11, 2010 at 6:14 pm
    There seem to be plenty of tutorials around about how to smash an object by throwing a ball or something at it, object smashes, ball stays intact. But how about two objects colliding and both smashing. It seems difficult as you’d need to set the both rigid body tags on both fracture objects to trigger “On Collision”, and therefore neither would trigger as neither are colliding with a “triggered” object.
    Any ideas on this? Would be most helpful…
    Simon Robson replied 16 years, 6 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 11, 2010 at 7:12 pm
    I would have one tag set to trigger on collision, and I’d keyframe the the other one so that it becomes dynamic one frame before the objects collide.
  • Adam Trachtenberg
    March 11, 2010 at 7:28 pm
    Instead of keyframe dynamics off/on, you can also set the second object to activate at velocity peak. Then it’s a question of tweaking the motion.
  • Simon Robson
    March 11, 2010 at 8:42 pm
    Thanks Adam. I’d seen those solutions but wondered if there was some more specialised way of dealing with this problem. Both solutions, although fine for my purposes in this instance are obviously not accurate; objects start to repel each other before they are influenced by the colliding object. Perhaps this is something Maxon might look at for Mograph 3?
    Thanks for your help,
    Simon
