Activity Forums Maxon Cinema 4D modifying “vibrate”
  • modifying “vibrate”
    Posted by Brian Smith on April 29, 2007 at 11:02 pm
    Hey guys, i need to figure out how to modify a “vibrate” expression to decay. the object needs to have a violent shake then suddenly stop and fall into place with a slight bounce. i have the vibrate down perfect, but I’m still very new to c4d, espeically with animating and expressions. if i could import the object and lights in to AE, I could do it there, but I have yet to figure that out.
    any insight??
    thanks guys!
    -BS
    Adam Trachtenberg replied 19 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 30, 2007 at 3:04 pm
    You can animate any parameter in Cinema that has a small circle to the left of its name in the Attributes Manager. You do that by simply Ctrl + clicking on the circle, which causes it to turn solid red.
    You can export cameras and lights to AE using the compositing project file options in the Render>Save dialogue. You’ll have to install the C4D->AE plugin in AE. The plugin is found in your Cinema>Exchange Plugins folder.
    After you install the plugin you can open the .aec file that Cinema creates in AE and it will automatically import your Cinema camera, lights, etc.
