Activity › Forums › DaVinci Resolve › Modifying Timecode With XML
Posted by Illya Laney on July 15, 2011 at 8:52 pmIn FCP I need a quick way of replacing the Media Start column with timecode from an XML(created using a modified ALE in Cinema Tools). The offline material has different timecode than the source media so the EDL from editorial isn’t in Resolve.
twitter.com/illyalaney
nextLAB Mobile
SpeedGrade DI
Resolve
da Vinci 8:8:8 Renaissance
Color
TruelightRohit Gupta replied 15 years, 1 month ago 3 Members · 5 Replies -
Illya Laney
July 15, 2011 at 9:49 pmI meant to say “The offline material has different timecode than the source media so the EDL from editorial doesn’t work in Resolve.”
nextLAB Mobile
SpeedGrade DI
Resolve
Color
Truelight -
Joseph Mastantuono
July 17, 2011 at 1:27 amIs it all offset by an hour or something? Or all completely off? If it’s all completely I think you’re just in for a painful conform.
Joseph Mastantuono
Online Editor – Colorist – Post Consultant
Brooklyn based finishing at reasonable prices
917.969.1583 -
Illya Laney
July 17, 2011 at 3:59 amI’ve read that you can modify clips/quicktimes in the XML documentation, but there’s not any more info than just a quick reference.
nextLAB Mobile
SpeedGrade DI
Resolve
Color
Truelight -
Joseph Mastantuono
July 19, 2011 at 4:02 pmI have had friend who are a bit more comfortable with coding than I am write simple Find & Replace scripts with a little math in it for a program that got telecine’d with timecode exactly 10 minutes off.
You can just open the XML in text edit, but at that point it’s most often fast to just do a visual match in FCP. Although since I’ve done loads of conforms from scratch from projects with no timecode, I’ve got really fast, so YMMV…
I would look into seeing if you can open the XML in some sort of Spreadsheet software. I remember using excel to let assistant producers log with a HDV deck back in the days of tape, and getting that into FCP. There were even scripts that could convert the files into XML’s. You *might* get some sort of mileage out of that workflow.
Please post your results if you find anything.
Joseph Mastantuono
917.969.1583 -
Rohit Gupta
July 19, 2011 at 4:04 pmIf this is just a timecode offset on the source clips, you can add the clips manually to the media pool with the offset (in frames), and then load the XML choosing to not import the media automatically.
Hope this helps!
