Activity Forums VEGAS Pro Modifying Four Points Script
  • Modifying Four Points Script
    Posted by Bill Cortez on February 22, 2009 at 6:07 am
    I have installed Edward Troxel’s Four Points script (I’m using Veges Pro 8c) and it works great. Can I modify the script so that the nodes are, for example, 6 frames outside the region and 6 frames inside the region (nodes are 12 frames apart). Thanks, Bill.
    Bill Cortez replied 17 years, 7 months ago 2 Members · 2 Replies
  • Edward Troxel
    February 22, 2009 at 1:33 pm
    Where you specify the separating timecode, put a MINUS sign in front of the timecode and it will go OUT instead of IN.
    Edward Troxel
    JETDV Scripts
  • Bill Cortez
    February 22, 2009 at 6:34 pm
    Thanks Ed, I figured it out last night. I changed the timecode to 6 frames and I changed the SetPoints as follows:
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart – FPDist, ClipVol);
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart + FPDist, ClipVol);
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart + myVegas.Transport.LoopRegionLength – FPDist, ClipVol);
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart + myVegas.Transport.LoopRegionLength + FPDist, ClipVol);
    Thanks again, Bill.
