Activity Forums Adobe After Effects Expressions Modifying expression times to layer’s inPoint
  • Modifying expression times to layer’s inPoint
    Posted by Adam Levine on March 14, 2016 at 6:51 pm
    Hello! I’ve a serious problem. How can I use ease wizz expression without adding keyframes. I want to set it for time such as layer’s inPoint to inPoint+2 like that. And I’ve used a slider controller to change the eX value of the expression. So I’ve tried so many ways to change the expression. But it didn’t work. Here is that how I changed the expression. Please help me anyone. Master Dan, I think you can give me an idea.
    // Ease and Wizz 2.0.3 : inExpo : All keyframes
    // Ian Haigh (https://ianhaigh.com/easeandwizz/)
    // Last built: 2012-10-11T16:37:31+11:00
    // some defaults
    var p = 0.8; // period for elastic
    var a = 50; // amplitude for elastic
    var s = 1.70158; // overshoot amount for "back"
    function easeandwizz_inExpo(t, b, c, d) {
    return (t==0) ? b : c * Math.pow(2, 10 * (t/d - 1)) + b;
    function easeAndWizz() {
    var n = 0;
    if (numKeys > 0) {
    n = nearestKey(time).index;
    if (key(n).time > time) { n-- }
    try {
    var key1 = key(n);
    var key2 = key(n+1);
    } catch(e) {
    return null;
    // determine how many dimensions the keyframes need
    var dim = 1; // It's gotta have at least ONE dimension
    try {
    key(1)[1];
    dim = 2;
    key(1)[2];
    dim = 3;
    } catch(e) {}
    t = time - key1.time;
    d = key2.time - key1.time;
    sX = key1[0];
    eX = key2[0] - key1[0];
    if (dim >= 2) {
    sY = key1[1];
    eY = key2[1] - key1[1];
    if (dim >= 3) {
    sZ = key1[2];
    eZ = key2[2] - key1[2];
    if ((time < key1.time) || (time > key2.time)) {
    return value;
    } else {
    val1 = easeandwizz_inExpo(t, sX, eX, d, a, p, s);
    switch (dim) {
    case 1:
    return val1;
    break;
    case 2:
    val2 = easeandwizz_inExpo(t, sY, eY, d, a, p, s);
    return [val1, val2];
    break;
    case 3:
    val3 = easeandwizz_inExpo(t, sZ, eZ, d, a, p, s);
    return [val1, val2, val3];
    break;
    default:
    return null;
    (easeAndWizz() || value);
    changed to :
    t = time - inPoint;
    d = inPoint+2 - inPoint;
    sX = 960;
    eX = 960 - thisComp.layer("ctrl").effect("Value")(1);
    if (dim >= 2) {
    sY = 380;
    eY = 380;
    if (dim >= 3) {
    sZ = 0;
    eZ = 0;
    Adam Levine replied 10 years, 5 months ago 2 Members · 4 Replies
  • Dan Ebberts
    March 14, 2016 at 7:59 pm
    Something like this maybe:
    v1 = value;
    v2 = effect("Slider Control")("Slider");
    t1 = inPoint;
    t2 = inPoint + 2;
    if (time < t1)
    v1
    else if (time > t2)
    v2
    else{
    d = t2 - t1;
    dv = v2 - v1;
    t = (time - t1)/d;
    v1 + dv*Math.exp(10*(t-1));
    Dan
  • Adam Levine
    March 14, 2016 at 9:17 pm
    First thank you master Dan for your quick reply. So I changed the expression like this as you said. But it’s not working. 🙁 Sorry for asking. Can you give me a another idea please.
    // some defaults
    var n = 0;
    if (numKeys > 0) {
    try {
    var key1 = key(n);
    } catch(e) {
    return null;
    try {
    key(1)[1];
    dim = 2;
    key(1)[2];
    dim = 3;
    } catch(e) {}
    sX = value[0];
    eX = thisComp.layer("ctrl").effect("Value")(1);
    t1 = inPoint;
    t2 = inPoint + 2;
    if (time < t1)
    v1
    else if (time > t2)
    v2
    else{
    d = t2 - t1;
    dv = eX - sX;
    t = (time - t1)/d;
    if (dim >= 2) {
    sY = value[1];
    eY = value[1];
    if (dim >= 3) {
    sZ = value[2];
    eZ = value[2];
    return value;
    } else {
    switch (dim) {
    case 1:
    return val1;
    break;
    case 2:
    break;
    case 3:
    break;
    default:
    return null;
  • Dan Ebberts
    March 14, 2016 at 9:51 pm
    That wasn’t meant to be a modification to your expression, it’s an example of a non-keyframed expoIn expression.
    Dan
  • Adam Levine
    March 15, 2016 at 5:40 am
    Thank you for your gratitude master Dan. But sorry asking again. Can give me an idea to modify my expression please.
